849 NH baler chain link replacement
I've heard that when your chain stretches and is starting to jump off the main drive cog you can remove one ladder bar worth of chain and thus tighten things back up. wondering if anyone has done this and if so how hard is it. I've seen pictures in the factory manual of chain replacement. Looks like they use two come-alongs and slowly release tension. then remove the link and tighten back up using the come-alongs. if anyone has done this please reply. need to get the baler ready for hay season. have 65 acres of Sorghum Sudan grass, 50 acres of pasture and with us finally getting rain in North Dakota I'm going to need something that can make a bale or two.
I don't know about he NH849 but on a NH850 I had to replace a couple of broken links on the bale chain. I lifted the gate to full open and use a com-a-long to put slack in the chain area I needed to repair took out the bad link and put in new ones. Still have a couple spares so if/when it happen again I have them on hand
Release the tension on the apron chain pull it together and cut one set of links out just like you would a roller chain and put it back together
