850 3 pt question
cmkmtrucker
My first tractor is a '55 850. Ive only had it a few days and today i hooked a scrape blade to it and it wouldnt lower enough for the blade to touch the ground when it was in position control. I put it in draft control and it went lower but when i tried to raise it, it only came up a few inches. Is this normal, an adjusrment problem or is something else wrong?
That sounds like you need an overhaul/adjustment of the lift cover. This subject has been discussed thousands of times on this website. Search the archives for "lift cover", get a FO-20 manual, a lift cover gasket kit and a cam follower pin then go for it.
