850 still not running
thommoos
Earlier i had posted that the 850 would not run. I finally have determined that I have very weak spark coming for the distributor. It will not jump 1/16 of an inch. I have been chasing this for about 3 weeks. It has a new coil, cap, button, wire, sparkles, points, and condesor. This is a 12v tractor. I double check points gap at.025. I have a fire from the coil wire that will jump 3/8 inch, it is a white blue arch.
Engine spins over great, proper fuel drain from carb will fill a pint in under 2 minutes.
Where do I go from her?
New cap and rotor do you have the rotor clip in place so the rotor is a tight fit?? If you do not then good chance the rotor is not where it needs to be when it should line up in the cap or you have the never right China TSC parts and one or both are bad from the get go
TSC parts many times do not fit as they should and are poorly made. As for part numbers for Napa sorry I do not have a Napa with in 50 miles of me so I get stuff at O'Reilly's
TSC is probably tisco parts. not super quality.. but if you are getting spark at coil but not from distribuitor, then points and condensor are good.
lets figure out where you are loosing spar past the coil secondary wire.
could be damaged cap, rotor, etc.
do you hav ethe rotor clip as asked.?
here are other ignition part numbers.. but just save these. your tisco points are working if it is making spark at the coil secondary. ( now.. rotor and cap may be another thing! )
Side-Mount Distributor: 8n thru 4 cyl thousand series
gap points to .025
NAPA #CS749
NAPA HEAVY DUTY PIERCED (ventilated) #CS753
Standard Ignition #FD-8081
Standard Ignition Blue Streak #FD-8081X (Premium)
Condensor:
NAPA #FA66
Standard Ignition #FD-75
Standard Ignition Blue Streak #FD75X (Premium)
Rotor:
NAPA #FA67
Standard Ignition #FD-108
Distributor Cap:
NAPA #FA352
Standard Ignition #FD-128
side mount points hold down screws #8-32 X 3/16
FORD AUTOMOBILE dealer parts counter. come with built-in lockwasher. p/n 355047-S7 (#8-32 X 0.19)
All 4 cyl models can use AL-437 or champion H12 spark plugs instead of OEM Champion H10 or AL 216 plugs.
Finally got it running white spark don't get it changed condenser , hit first time. Went and put on hay spear and moved 32 5x5's
