850 three pt
histoman
Hi everyone, my three pt is jerky when raising, sometimes doesn"t want to raise at all. Changed the hydraulic fluid, and it"s still doing it. Any suggestions? Want to get it working reliably before the snow flies. Thanks.
jerky on the rise is likely the pistons inthe pump,, especially if it stays at height once lifted.
thge not lifting at all could be a sticky unloading valve.
what oil ya using?
soundguy
Soundguy is on the right track for the jerkiness. I'm thinking the pump is at fault also. Could be the pistons or check valves. Another possibility is the pump is pulling air around the shaft seal or in from a manifold o-rings. I would try priming the pump before going much further. If that cures the problem, great. If it comes back later - think shaft seal.
A wobble shaft, bearings, and seal cured my 660's jerkiness. New check valve springs helped, but did not cure.
Using hydraulic tractor oil from TSC, not the universal hydraulic/transmission oil. It does leak down over a several hour period also.
i'm confused by your answer..
you say using 'hyd tractor oil'.. i'm taking that to be a utf since you mention 'tractor' oil.. as plain hyd oil is not tractor application specific. ie.. there is HYD oil, then there is 'tractor oil, which generically refeers to a universal tractor fluid.
I'm not a fan of using jack oil or plain aw style hyd oils in a tractor..
soundguy
