Royse
- Location
- Ionia County, Michigan
3pt lift arms will raise, slowly, when empty to 18 inches then
stop. They will stay at that height and hold my weight even
with the tractor shut off, until the touch control is lowered.
There is also very little pressure at the remote valve.
I plumbed a gauge into the remote port and it moved off zero,
but not up to the first mark, which is 100 psi, so maybe 50 psi?
As far as I can tell the pump is turning since the proofmeter
drive is turning. I also bled the air at the pump and there were
a few air bubbles not all that much. Oil level is full.
I can look in the hydraulic filler cap and see the end of the
lift cylinder. There doesn't appear to be any oil leaking there.
So what do you think? Relieve valve? Bad line in the trans?
How can I tell without throwing parts at it?
