I bought an 851 from a friend who bought it from a church. It is a nice one that has been converted to 12 volt with a 10SI. My friend didn't realize it didn't have power steering and live PTO, so I ended up with it.
So, I always had trouble starting it, but it ran fine once started. It would crank for a while with nothing and then when you release the starter button, it would start. No problem, I just learned to not crank long. Just hit the button and it was running. Then, it got to where it wouldn't start at all. If I put a charger on the battery, all was good. It had a 6 volt coil with a resistor of unknown resistance. The battery was getting weak. The resister had two coils side by side, but only one was being used. The spark was weak. I didn't check the resistance, but am sure it has to much resistance. Now, I put a small jumper wire on one end of the resister and when I start it, I just bypass the resister and it starts fine. I then unhook the wire.. So, when cranking with a weak battery, the voltage supplied to the coil wasn't enough to get a good spark, but when you released the starter button, the engine coasted enough (they really crank fast) with full voltage to start. Makes sense to me. Of course, now with the cold weather it won't start and will barely crank. No biggie, I don't use it now anyway.
This brings up the resistor bypass circuit on a lot of Delco systems. My MF TLB gasser has one and it will start anytime. There is nothing like shooting 12 volts to a 6 volt coil to make a hot spark. I don't know why they didn't put that on everything - back in the day at least.
