hillbilly2
I just purchased a non running 855.
The previous owner said it quit running while they were using it so they replaced it with a new one.
So far I have figured out that it needs a fuel shutoff solenoid but I can manually bypass that to get fuel to the injectors. I’ve bled it at each injector and it will somewhat fire on one cylinder.
The other issue that I didn’t see right away is one of the freeze blocks is missing. It is the one directly behind injection pump. Would the missing freeze plug mean maybe it was overheated?
Currentlly I’m thinking it could be one of two problems.
1. It possibly was overheated and doesn’t have enough compression to start.
2 Injection pump timing is incorrect.
Thanks
Thanks
