I had replaced a tank valve several years ago because the shut off head was broken when I acquired the tractor. Recently I noticed a very slow leak from that area under the tank. I removed the hood and tank and took off the valve. The first thing I noticed was the skinny o-ring had swelled and wouldn't fit the groove in the valve (not the thickness of the o-ring - the ring size). I called the FNH dealer and had him send me a new o-ring. By the time it arrived I noticed the old one had dried out and shrunk back to normal size and looked identical to the new one. I also had an old o-ring from another ford shutoff valve that I had replaced on a different Ford tractor (had no problems with that one) that was much thicker than the replacement. I tried that with my leaker and it still leaks. It is so small a leak that you can't see where it comes from. I have the tank on saw horses with a plastic sheet under it and it might leak a tablespoon over night and the area on the tank surface surrounding the valve is wet. Would I be foolish to try a bead of gas resistant sealer in the area outside of the o-ring between the valve and tank? Any other ideas?
