JAC FARMING
Ok so back to square 1 again ive had this apart a bunch of times now. New seals in the rearend. New brake discs. New master cylinder. New master cylinder seal kit. New holland brake oil. Fixed the pitting in the rearend. Pump the left brake up and just like every time before it builds hardly any pressure and looses pressure when you release the pedal. The left brake will also not release the tractor will not even freewheel down a hill. Before i push this POS off a cliff is there any other solutions. Also brake discs are not warped that i can tell. Also I separated the axle housing some pumped the pedal and it pushes the piston out just fine just not much pressure and it seems like it should suck back in.
[video play=false:4aed11cf9e]https://forums.yesterdaystractors.com/videos/mvvideo78824.mp4[/video:4aed11cf9e]
[video play=false:4aed11cf9e]https://forums.yesterdaystractors.com/videos/mvvideo78826.mp4[/video:4aed11cf9e]
