861 clutch replacement
ted glennon
I separated the trans and engine on my 861 powermaster. I found a broken metal washer in the bottom of the bell housing. The washer 2" O.D. with a 1 1/8" I.D. the washer is approx 3/16" thick. The I.D has 2 flat areas that are 180 degrees opposite and the O.D. has a 1/4" wide x 1/4" deep slot. Does anyone know what this part is?
I haven't installed the starter yet. I'll look it over good. Thanks
If the starter was working before you split the tractor, likely the piece is from a previous starter which failed. Very common to find pieces of starters when splitting a tractor.
