ron861
I have a 1959 861 Diesel, trying to locate the top cover for the fuel filter. I ordered from Messicks but order come back no longer available, Part # 311865. The top cover is leaking fuel, I think from the center bolt. Wondering if any one has tried to pull the center bolt and reseal ?
I replaced the seal on the bleed screw, that is ok, leaks is from the center mounting bolt that goes through the filter. Thinking there must be a seal of some kind under the bolt head, but bolt and cover are sold as a assembly, not meant to come apart.
You might ask your Ford (NH) dealer to search for NOS parts across the NH web. I've used this method previously with success on some NLS parts. Not saying they'll come up with anything, but then again they just might.
Yes, that was my original plan. But the bolt is retained internally to the cover. I have had the cover off, looked over the under side and can't see what keeps the bolt retained, must be a internal locking ring that locks into a groove in the bolt. I can still use the tractor, so don't want to get to aggressive and break the cover.
By the way Ultradog , I'm over here in Western Wisconsin.
Thanks All
