861 electrical question
jtflyer
The spot marked with a question is what? junction box? THX, JT
The proper name is Terminal Block but if you look it up at a auto parts web site such as Napa you need to search Junction Block.
You can buy one at any local auto parts store for about $5. It is just a piece of hard plastic with a couple of screws molded into it. The plastic keeps the screws isolated from ground so you can join hot wires at this point.
The original terminal block bolted to a piece of metal on the steering column just above the voltage regulator.
(quoted from post at 20:30:49 11/19/10) The proper name is Terminal Block but if you look it up at a auto parts web site such as Napa you need to search Junction Block.
ohn, I wasn't going to put this photo up, since it is a NAA, but by your description of location, it is likely unchanged for his 860??
