FarmerBlair
Sorry about the long post.
I knew it would cost more than the tractor's value but decided to finally have the engine professionally rebuilt on my 861 (gas). But I've been having nothing but problems getting the work done right. I paid over $5k to a tractor repair shop for a complete engine rebuild, along with a new clutch. I got it back 7 months later and discovered a rear engine seal leak among many other issues. I didn't know how serious the leak was until later when mowing on hilly ground and nearly lost all oil pressure. The repair shop would not cover the cost to fix it because it was a couple months past the warranty, even though they admitted they had such problems with rope seals being too short. They wanted another up to $1200 to replace the seal. There's only about 10 hours on the rebuilt engine.
I took the tractor to another shop in Lancaster PA that my neighbor farmer recommended. The shop found the bearings were also shot, so I told him to go ahead and replace those (again) while replacing the seals. This cost another $1200 on top of the engine rebuild costs.
I just got the tractor back, and it leaks oil at the back of the oil pan near the bell housing. I replaced the gasket myself. I smoothed out out hardened RT sealant that caused the leak along the gasket. But now I see oil dribbling down the adapter plate between the engine and tranny. It was doing that before, but now I can tell it isn't from the separate pan leak.
I asked the last mechanic (in PA) whether he split the tractor to replace seals and he said he did all the work from underneath. He said he used a 2-piece rubber seal that he worked in and then sealed the sides with an RT sealant like you hear about. He mentioned about probably having to pull the crank if he went with the rope seal. At the time I wasn't sure that was true, but didn't ask further. I'm not a mechanic.
So far I don't see engine oil leaking out the bell housing opening (with the plate with a cotter pin off) as its running, even with the front end of the tractor elevated. I left it running for at least 30 minutes so I'm hoping that's that.
But what about this weeping oil between the engine and the adapter plate? Is this from a leaking main oil seal? Oil starts dribbling down the plate after a couple minutes of running.
Had another thought is can you replace bearings from underneath (through oil pan)? Or is that just a partial job?
Thanks for any input.
