Well, now that I'm pretty sure I have all my issues with fuel flow worked out, (knock on wood) how do you think these #'s look? I ran the tractor for about 20 mins. at various rpms and here's what I have without any physical load on it yet.
At idle (about 600 rpm on my proofmeter) 29 psi oil pressure, at 900 rpms 35 psi, at 1100 rpms 39 psi and at 1400 rpm 40 psi.
Exhaust manifold temp anywhere from 380°F to 450°F .
Bottom radiator hose 110°F and at the t'stat neck 135°F.
Outside temp is 80°F.
Probably not the most prudent time to ask but do you think it will handle plowing snow with an 8ft. Woods blade? (350lbs.) What gear and what rpm do you run at while plowing or is it just trial and error and keep the tires from spinning? Nothing in the tires and no weights on the tractor.
