871 rear work light
Is the bulb frosted? what about the bolt to fender, wasn't hollow originally, but hole for switch on casing. Don't see many Fords around here, restored at least and letting this restore go to long, but money lets you down sometimes. College,Taxes, but no death thankfully. Yhanks for info. Dave
It should look like this one.
The mounting bolt is hollow for the wire to go through and there's a switch on the housing. If your mounting bolt is not hollow you may not have an original Ford/CM Hall worklight.
The mounting bolt is smaller than headlight, right. If so need part number and will direct to you. Got one from somewhere and same as headlight. Switch part number also.
