88 into 880
88-1175
Looking to update a super 88 into a 880.i have a few questions.are the power boosters all identical in the percentage of speed drop or are certain yrs less drop.id like to change the radiator shroud and grill on the 88 to look like a 880,will the hood need changed too or does the 880 nose piece match UK p with the 88 hood.will the 880 nose piece work on the 88 tub.this isnt a show restoration,just a puller
(quoted from post at 10:41:39 07/24/19) Looking to update a super 88 into a 880.i have a few questions.are the power boosters all identical in the percentage of speed drop or are certain yrs less drop.id like to change the radiator shroud and grill on the 88 to look like a 880,will the hood need changed too or does the 880 nose piece match UK p with the 88 hood.will the 880 nose piece work on the 88 tub.this isnt a show restoration,just a puller
Or just put an 880 engine into the 88?
A local puller I see occasionally put 880 sheet metal on his Super 88. If you knew what to look for you would know it wasn't right but was definitely passable. Nose and hood.
