88 Sleeves in 77 Block
I looked through the archives and didn't exactly find the answer I was looking for, my question is:
1. If you have a 77 block that is bored to accept 88 sleeves, do the 88 sleeves need to be shortened. If they are shortened new o-ring grooves need cut I assume.
2. Does the head still fit fine? The head gasket would need to be custom though I'm guessing.
It would be much easier to call Korves Oliver (external_link.com)and have them send you a 3 3/4" sleeve and piston kit for a 77. I bet that this kit would cost you less than the machine work it would take to fit the 88 sleeves if its even possible. This would get you to the same bore as most 88/Super 88/880's. An 88 originally had 3 1/2" pistons, but most have been overhauled with the 3 3/4".I asked this question a few months ago and was told the 77 sleeve is shorter.
