880 injection pump
Fuel rod screw is under the hex plug on governor top rear. 6 sided slotted nut will stay where it's turned when tightened. Start with 1 turn and go from there.
How much horse power do you have now? Have you had the tractor on the dynometer? Maybe you should start with a good tune up! How much horse power do you want. The one turn diesel tech told you is the standard setting for a 950 Oliver
