8970 fwd problems... connector???
i have a ford 8970 that gives me a F312 code ( fwd shorted). If i disconnect the solenoid it says open. i switched it with the diff lock solenoid and it still gives the same code. all the wiring looks fine. could it be the connector shorting out? seems ok. any idea where to find a replacement? any help would great. thanks
You need to follow diagnostics on the fault. There is a proceedure listed in the book for F 312. It will likely involve an ohmmeter and some specific sequence of testing. Could be a fault in connectors, wiring or even CCM.
