8970 genesis dead cylinder
i was gonna haul manure today and when i pulled out on the road i noticed i had no power and it was chugging. We cracked all the lines at the injector pump and the #2 (second one from the front) had no fuel coming out at all. pulled the line completly off and nothin. any know anything about these? Bosch P3000 pump. can i take the two bolts out of the cylnder thing on top of pump, or is my only option to remove the whole pump and send it in? any help would be awesome... either here, my email.. [email protected] thanks everyone, love this site..
Would recommend having a pump shop work on this. Those Bosch pumps are fairly complex. In addition, you could mess up individual metering and timing for that element if you're not careful. Then you could end up with a "hot" hole and later on, a cracked piston.
so i bought a new holland shop manual. we are going to pull the injection pump off. what is this go/no go pin thing? ford doesn't use timing marks on the gears? i don't fully understand how this works, as far as i can tell i need to go to
(reply to post at 03:00:43 1 degrees before tdc and then insert this pin.. what's the pin for? and how do i make sure i've got it in time when replacing it? ( sending it to a pump shop) all the pumps i've seen always had timing marks... thanks guys
