I converted my 1950 8N to a 12V system a few years ago and am glad I did it. However, even though I bought the kit to do the conversion using a Delco alternator, the brackets provided didn't align the alternator pulley with the water pump and crankshaft pulleys on the tractor. Since I tried to do it without removing the loader, and time was short, it was difficult to work on and I finally got it close and called it good.
Now my crankshaft pulley (which I knew was worn when I did the conversion, but let it go due to lack of time) needs to be replaced so I removed the loader and dismantled the tractor. Now that I can see everything clearly I decided to further modify the alternator mounting in order to align the pulleys, but here is what I've found. The front of the pulleys are lined up pretty well, but all 3 pulleys are different widths with the alternator pulley being the narrowest by far. With the set up I was running, the fan belt was rubbing on the fan behind the alternator pulley which, of course, pretty much destroyed the belt.
As long as the tractor is apart, besides the bad crankshaft pulley I'm going to replace the water pump since it will never be easier than now. I'm hoping the 2 new parts have identical width pulleys, but I'm assuming the alternator pulley will still be much narrower than the other two.
Did I miss a step in the conversion saying that I had to install a different pulley on the alternator? I was under the impression that a Delco alternator was a bolt on option. After I get the new parts installed I need to modify the alternator mounting bracket to improve the alignment, but do I need a different pulley for the Delco alternator?
I did some searching of the archives but haven't found this particular issue discussed. I'd appreciate any advice/experience anyone has to offer.
