I can't help you w/ kits either because all 3 of my N's are 6v. The only 12v tractor is the 740 & it came that way.
A 12v kit from this site sells for $134 plus shipping. The last generator I had rebuilt cost me $85.
If you don't have a local rebuild shop, these guys do 'mail order' work; give them a call to get a quote & shipping info.
And, they also do carbs, starters, brakes, water pumps, clutches, etc.
Automotive Manufacturers Incorporated
2400 N Lombardy St
Richmond, VA 23220
(804) 321-6861
As to the pros & cons of converting to 12v, this debate comes up here w/ such frequency that you would benefit from doing an archives search on the topic. Generally speaking, you will find a few facts, a lot of opinion, & unfortunately, a little BS. And sometimes you will find factual information that isn’t the least bit relevant to a 12v conversion on a 23 hp, 60 year old tractor. ("the auto industry did it 40 years ago")
Generally speaking, the opinions can be grouped in three broad categories:
1. 12v conversions are the greatest invention since sliced bread.
2. If it's not broke, don't fix it.
3. Spend whatever it takes to keep it 6v.
From my experience, I've only found two reasons to convert an N to 12v: If you need to run 12v equipment (sprayers, pumps, lights, etc) or your N has poor compression (like less than 90 lbs) and you do not want to rebuild it, then a 12v conversion makes sense. If an N is hard to start in cold weather (or any weather) find out why & fix it! These tractors have low compression, low HP engines and will start just fine on 6v. There is nothing inherently 'wrong' w/ a 12v conversion. The problem is that there are about 6 different ways to convert the tractor to 12v, all of them work, and an infinite number of ways to do it wrong. If you have a basic understanding of tractor mechanics, you can buy a quality kit & do it correctly. Or, you can buy an alternator & fabricate brackets if you are skilled at that sort of stuff. Of course, if you have a basic understanding of tractor mechanics, you could just as easily fix the problem that you are trying to cure with the 12v conversion. Most problems we read about w/ 12v conversions are as a result of folks getting in over their heads trying to fabricate a conversion, using inferior kits or using kits w/ directions written in Chinese, or buying tractors w/ "Bubba" conversions and now the new owner is stuck with trying to figure it out. I can tell you that a wage earning mechanic known to many of us on this board summed up every conversion kit he was familiar with by saying that all are bad & some are worse. He makes his own for that very reason.
Now before the 12v advocates give me a spanking, let me add that lots of folks around here have 12v conversions & are perfectly happy w/ them because the conversions were done correctly. 12v is also more forgiving of poor grounds/weak cables, etc than 6v, so keeping everything "clean, bright & tight" in the system is not as critical. 12v gives you twice as much current & a faster spinning starter. And, because 6v headlights are 35w & 12v are 55w, the headlights are brighter.
You will spend $134 for a kit. If you install it correctly you will have an easy starting tractor for a long time. And, the 12 conversion will have just about nothing to do w/ the good performance. What will make the real difference is the new wiring, cables, clean grounds & new battery.
All three of my N's are 6v & they all three start the first time, every time, no matter what the weather. You will find that to be the case with folks who live in a lot of places much colder than VA. Plenty of 6v tractors start just fine in MI, NY, WI.....and have been doing so for years. Because they have the correct size cables, good batteries, & clean, bright & tight grounds & connections. And, the correct gaskets in the distributor.
If you do decide that a 12v conversion is the way to go, plenty of folks on this board have done them and they work well, so you have come to the right place for help!
50 Tips
