(quoted from post at 20:17:34 03/21/16) To remove the guide you going to have to remove the valve. To do so here we go...remove carb, manifold, air cleaner tube, valve covers, coil and mount, and oil filter so your tractor should look like so.....
your going to need a valve spring compressor or you can make one out of a "C" clamp. Here is mine.
your valves will be slightly recessed in the block.....place a piece of smooth scrap wood over the valve you will be working on. Use the clamp to compress the spring-making sure the fork goes under the plate at the bottom of the spring but allows the valve to pass through the fork. You will see the two small "Half Moon" shaped retaining clips remove those clips.....
Once the retaining clips are removed the valve will pull out straight from the top leaving the bushing, spring and bottom plate.
remove the bottom plate and spring carefully.
now you should be able to see the bushing from the top...put a tall socket in the hole and use a hammer to drive the bushing down.
push the bushing down far enough to expose another "C" retaining clip...remove the clip then finish pushing the bushing down and out.
and your valves and valve assemblies are now removed.
make sure you remember which valve goes where and try to keep the assembly to each valve together. I soaked mine in a solvent. this is how I kept tract of my valves and assemblies.
also in the below the lifters there are several hole big enough to lose the tiny moon clip in......cover those hole to prevent dropping them down there......you can see the hole right above my index finger......which is right below where those clips come off.......
And that's all I got to say about that.....
(quoted from post at 23:12:50 03/22/16) Zane the way you describe is the way you can do it if the guides will budge.......My valve guides were stuck (wouldn't move) and barely moved with me using the hammer. The original poster said his guides are stuck too (a lot of people have this problem). This is how you get them out in that case.
