8N 3pt. won't hold position
Cptwayne
I tried to send this yesterday; but I guess I did something wrong. I have an 8N with a 9N engine. When I bought the tractor it would barely lift and implement, so I removed the side cover and observed that the relief valve was bypassing, so I replaced it, after that the three point would only go full of or full down it would not stop anywhere in between. I pulled the top cover and found that the cam follower was almost worn half, and the cam had a groove cut in it I replaced the cam follower, and dressed the surface of the cam. When I reassembled it I tried to set the springs to the links described in the maintenance book but it still does the same thing I forgot to mention that I did try a Zane thing replica made by Redstone. It didn't work either, I can't help but think that it is an adjustment; but the only information I can find is measuring the springs. Does anybody have any suggestions? I spoke with Archie Tanner about it, and he said he remembers that there was a rigging fixture, but I haven't been able to find anything out about that. Help and/or advice will be greatly appreciated!
Fist thing I would want to check is that the [draft/position] control lever is pointing up (toward sky, not toward front of tractor)for position control mode.
Check and verify the hydraulic pump control valve is still spring loaded so it is pushed out of the seat when control arm moves back away from the pump. Should be a simple check through right side cover. If the linkage and top cover is not the problem it maybe that the exhaust valve and control valve are not acting together!
