8n - 9n implements
I'm just curious as to whether the implements from an 8n or 9n will fit a 1025r john deere. Thanks.
The 1025R has a "limited" CAT 1 three-point hitch.
As I understand it, the arms are shorter, meaning as they lift they swing through a lesser arc and full-sized CAT 1 implements likely won't lift as high as with an old "N".
Also, the geometry between the lift arms and the top link is different, which affects how implements tip forward as they raise.
All of which may or may not be a problem depending upon exactly what implement you intend to use.
