flameeater
Here is a strange one. I went to do a brake job on my 8n, which is not in the best shape, but it works (it has spent the last several years at my fathers and he has been using it). I decided to change the outer seals since I was going to be there anyway, and I wanted to make the most out of it. Only then did I realize that instead of the 2in nut, there was a castle nut, and it had been welded.
Ordered a proper 2in nut, ground off the welds, and split the nut to get it off. Managed to save the threads, but the shaft is too small for the "correct" nut, at least on that side (left). Nut fits fine on the other side's exposed threads.
Took the nut around to hardware stores, Fastnal, and tractor supply, but no one carries anything to replace it with. The closest was a 1-8 bolt from tractor supply that I could thread it on, but when I got the corresponding nut and washers home, they wound up being slightly too small.
The threads look factory as far as I can tell. This axle seems to otherwise be just fine. Could someone have shoved in a interchangeable axle from a different tractor? Were replacements made with smaller threading? Any info would help.
I suppose I could just replace the axle, but other than no friction material left on the brakes, there is nothing really wrong with it. Any ideas, or suggestions? Thanks!
