Grandpa's 8N
After making several post on here about the brake locking up. I finally put a new axle on the right side and that fixed my brake issue. I used the same hub ( which had been replaced). I had even put washers behind the brake drum (tried a couple of these also) to space it out farther, but it was still dragging. I was feed up and finally ordered a axle and put it in. It was still up on the blocks when I climbed up in the seat and pushed on the pedal. The pedal even pushed different. Shredded the road ditch, shredded some corn stalks, drug the drive way and used the brake and it never once even thought about grabbing. FINALLY. One question I have is
When I installed flat washers between the brake drum and the hub, the brake would still want to drag, but when I put the new axle in it didn"t- both processes spaced the brake drum out- but why did only replacing the axle work (same hub). (The threads showing on the axle by the nut was reduced by about 2 threads- about the same thickness as the washers I used)- No the washers are not on the wheel hub now, I know that is not the proper fix. I was using washers as a test. I am glad it worked, but don"t understand why the washers didn"t fix it.
