'51 8n. Not sure of the right terminology here, but the right brake was "hanging up", i.e. getting stuck against the drum and allowing the brake lever to fall to the floor board. Typically, I stop, reverse and it releases.
I pulled it apart and it was covered with black stuff. At one time the seal must have been leaking, but now that the tractor is in use, the backing plate is dry and no sign of leak.
I cleaned up the shoes, and sprayed them down with lots of brake cleaner and put everything back together.
It is better, but still locks up.
The shoes are in like new condition, made in Taiwan.
1. Is there supposed to be one of the shoes that has a little less pad on it? (Both shoes, top and bottom are exactly the same.)
2. I seem to remember from this site, that a leading edge of a pad should be beveled? Am I remembering that correctly?
3. Should I replace the one side? With oil being ground into the pad, will it ever be right?
Thanks.
Jim
Thanks.
Jim
