[b:c026c7f549][i:c026c7f549]
Robert;
You say:....."
i rebuilt the carb put it on and adjusted both screws out 1 turn . "
That's a fair place to start....BUT, with those settings, that will just get the engine to idle fair, and is only the starting settings for the M/S TSX carbs.
You now have to set the carb up, for your engine to run properly.!!
EVERY engine breaths diff., and every carb runs diff.,.....thus the adjust Idle/Air, and adj., main fuel screws.
Here is the way I do this, on every carb., that I rebuild.:
First check to make sure the firing order is correct...(1-2-4-3)....and that all sparkie wires are in the correct holes, on the distrib. cap!!!!!!
Then set the idle/air screw to 1 turn out
Set the main fuel adj. screw out 1 1/2 turns
(those are MY starting place)
Then start the engine and let it warm up to running temp, at just above idle.
Once the engine is warm, you can now set the idle/air adj. screw, by turning it in about 1/16th of a turn at a time. (Do this with the throttle at dead idle). What you should be listening for, as you adjust is, highest RPM.
Once that is obtained,....reach behind the carb and set the throttle screw down to lowest/smooth idle!!! (Around 400 to 500 RPMs on yer proof meter)
Finally....the Main fuel adj. screw can be set for high throttle operation.....(screw in for low fuel, and out for max fuel) This is for max power to the engine!!!! IF....ya have to turn that adj. screw out more than 2 turns....You have a problem with the carb......passage plugged up somewhere in the carb.!!!!!!!!!
You may have to do all this about 2-3 times ......OR MORE, to get it right.
If ya still have problems......post back for More info.
Gary
[/i:c026c7f549][/b:c026c7f549]
