8N carriage bolts
thelach
I need new carriage bolts for my 8N rear end tires. I'm looking at item # MIS063 at yesterdays parts list. I look at the picture and the bolts don't look like they have squares under the bolt heads. It looks like angles. Has anyone bought them before?
I needed the longer bolts for stabilizer brackets.
I ordered on line and picked up at local Fastenal outlet.
They look exactly the same as OEM, but because of the short threads and smooth shaft I did have to add an extra thick washer under the nut.
Joe
(quoted from post at 09:58:52 03/22/20) I need new carriage bolts for my 8N rear end tires. I'm looking at item # MIS063 at yesterdays parts list. I look at the picture and the bolts don't look like they have squares under the bolt heads. It looks like angles. Has anyone bought them before?
Part number 370938S36.
TOH
OEM hat rims #35079S8 5/8X18X 2 7/8"
Loop rims #370938S36 5/8X18X2 3/4"
Nut for both #33806S7
Washer for both #351505K16
Google the numbers are look here fer'em...
Welcome to the forum!
If you want exact as original, try Dennis Carpenter dot com.
Otherwise, any 5/8 by 3 or 4 inch carriage bolt will work.
They would be course thread instead of fine, and stick out
farther but they work.
