I recently picked up a 8N side dis. It starts and runs good. But it needs half choke to idle smoothly. It has a new coil, plugs, wires
and electronic ignition. The previous owner said he installed a new carburetor. I took it apart, and yes it did look clean and new. The
fuel flow seems ok. But will not idle smoothly unless you pull the choke half way out. Adjusting the idle screw seems to have little or
no effect on it. Actually it idles the best with the small screw completely removed. Maybe junk aftermarket carb. Wish I had the
original carb to rebuild. Any advise would be greatly appreciated.
