Premie-farmer
I have tracked my most recent 52 8N side mount no start problem to the stud at the dist. Little to no spark at points when I opened and closed them manually with key on. Have 6.33 volts both sides of key switch with key on (6.33 batt side and 0 coil side key off)and both sides of coil and when I took the wire off the dist from coil had 6.33 at the terminal where it connects to dist. When I reconnected the coil wire at dist had 0 points opened or closed. Took a look at wire that had been used to replace the copper strip as well as the terminal yep the wire was half off or barely connected and the insulation at the terminal was sliced as well grounding out my sparkies.
Ordered new conductor strip and insulator and terminal screw from Just 8n"s. Question is since I don"t have a copper strip how is it installed?
Oh by the way. It was easy to remove the stud bolt with the dist on the tractor just had to be careful and take the point plate off and line up the weights right there is enough room to take the screw out with needle nose pliers.
