1950 8N with a front mount distributor. It has a pretty good power draw when the tractor is off. It will kill the battery in about 2 days. When you hook up a new battery or jump it the generator spins. I’m assuming there should be a diode or something to keep this from happening?
The tractor shows its charging when it’s running. This still has the original 6vdc, positive ground setup. I’d like to fix the issue before buying a new battery.
I’m wondering if it is a bad diode if I can replace that without replacing the whole generator
