8n drag link
Use a splitting wedge under the nut after it is loosened up till flush .Tap the wedge in so it has some pressure on it then tap the steering arm with a hammer,or use two hammers and swedge the arm.
http://www.oldfordtractors.com/rep.htm#q15e
Loosen the nut almost all the way, hammer on the side of the pitman arm where the tie rod end goes through it, it will
pop loose.
