I need help. I recently purchased an 8N, not sure what year. It has been converted to 12V. It did not have a key switch on it, he said his son had lost the key to it so he had removed it and just had each end of the wires with a spade on them so you could put them together when starting. I purchased an original key switch for it on ebay and was going to replace it. When i did i noticed that it was hot all the time no matter what position the key was in, then i noticed that even with the switch removed and the wires hanging loose it still turned over when i pushed the start button. Then it stopped, nothing when i pushed the start button. After checking the voltage i noticed that the wire from the start button to the solenoid is always hot, even when it is not being engaged. Isn"t this wire supposed to be a ground? Have i somehow reversed the polarity or is it bleeding through somewhere? I"m not good with DC systems so any help would be appriciated. Thank you very much.
