Howdy, first time posting here, but have been reading and looking around for a while. I got a '49 8n that I have been going through for a couple months as time permits. It sat for 2-3 years before I got it so have been doing all the typical maintenance, rewire, plugs, distributor, fluid changes etc.
As I was doing a coolant flush the other day when I went to drain the block I found the threads on the block are just about completely stripped. I was hoping it would be the brass plug that was stripped, but replacing the plug with a new petcock I found it definitely is the threads in the block. I put some teflon tape on the new petcock hoping that it would help, and it does help, but not enough. When installing the new drain I can push the plug in almost 3/4 of the way in before it will catch any threads to screw in and then only get about 2 turns before it bottoms out. I does hold but this morning I noticed that some water had seeped past. Is there a way to fix this? I have not tried re-tapping the threads yet, but didn't really think that would help with how worn they are.
Anybody have any ideas?
