8n engine kit
John(IN)
1949 8n smokes and uses oil. Which engine kit would be recommended. The 4 ring pistons or the 3 ring pistons? Engine has .090 sleeves but I don't yet have a piston out to see what prior rebuild used. Why are the different piston options offered?
The informed consensus is 3 rings because 4 rings causes more sleeve wear. That being said, unless you plan on using the tractor as it was used when new, it won't make a bit of difference.
50 Tips
