8N engine rebuild
Is there a web site with specs for the 8n for a rebuilder? End play, main bearng clearance, rod clearance etc? Thanks, John Ayres
John........squander $25 (cheap) for the I&T FO-4 manual. Has all the specs you need. It also has pictures for the reading challenged ........respectfully, Dell
There will be a book with all the specs but here goes anyway: Mains 1 1/2 to 2 thous clearance
rods 2 thous clearance, end play from 6-9 thous, cam gear to cover 4-6 thous, Pistons 2 thous, ring gap 15 to 20 thous, piston pins, 2-4 tenths clearance, sleeves 1 thous press fit, valves to guide 1 to 1 1/2 thous clearance. Head and block should be resurfaced and check main cavities and maybe line hone and rod big end may have to be reconditioned.
