8N finally started
mrjim
8N, Side Mount, 6 volt. Cut off on me over two years ago, and I gave up on trying to get it started. Started messing with it again first of October and finally got her started today 10-16. I think a lot of my problem was spark plug and coil wires. I had it serviced at a dealer 3 years ago (because it was hard to start) and they put Motorcraft carbon wires on it and I've had problems every since. I put on a new set of Tisco Copper Core wires and it started. It's not running as smooth as it should, but I think with a little tweaking, it's gonna be fine. I need to clean the plugs, I may have flooded it before I got it started. I need to clean and check the point setting, I think I left the key on overnight, but it started. It's a great feeling when you see these old machines come back to life.
If you left the key on and the points happen to have been in the closed position
then you will need new points.
