I've ben working on a 8n and I will give as much info as I can. First off when it was purchased it had a knocking noise. Got it in the shop and drained the oil and the pan had coolant in it. pulled the head and # 2 sleeve was gone. Pulled the pan and the sleeve was in the oil pan all smashed up.
#4 sleeve pulled out by hand and all of the sleeve edges were below the block deck. by the way it dose not have cast sleeves it has the thin steel. #2 bore has about a 2 inch crack about half way down. I have two questions
#1 Is there anything that can be put on the outside of the sleeve or the inside of the bore to keep the coolant from leaking out after the sleeve is installed.
#2 what should the sleeve standout be if any. thanks for any and all replies.
