8n ford stuck Clutch
Eli McKeehan
bought tractor with problem, thought i could adjust clutch to disengage and didn"t work, start in gear to put pressure on clutch with breaks applied to pop loose and still stuck, what the easiest and best way to free clutch without splitting tractor up
I am just a newbie on here but I have seen the gurus say to try rocking the tractor using the ag prybar, The rear tires, I assume and see if that will free it up. Never had that to happen so don t know from my experience. Devious
Remove the Starter.
Rap on the Flywheel w/ a hammer
Clutch should be depressed when hitting
flywheel.
When storing when humid, hold down clutch pedal
w/ a screwdriver
When a clutch got stuck in one of the many Model A Fords i drove, we'd tow it up a steep paved street to the top, then we'd let it drift backwards, with the gear shift in Low gear position, and suddenly leave out the clutch pedal. Worked every time!
Heres how to park it (note wood block)
I don't know much and have only been living with an N for about 12 months but it is one that had both feet in the grave and is now a tool on the place I can't figure how I did without. Mine would stick again and again, tranny oil leaking out the front seal was root cause.
No question, only sure cure is to split it. All I put in was a clutch disk and and a tranny seal. Although sound advice from this great site, all the tips I got when I was asking cost as much time as just splitting it and forgeting it.
