50 model 8N side distributor will not start.
Have changed the following items: valve job last summer, new wiring, new distributor, new carburetor, new coil, new points, condensor, rotor cap, plugs checked good and in correct firing order, checked compression #1 80, #2 80, #3 80, #4 87. Checked engine timing 3 different times, Checked voltage, ignition switch to the coil through ballast resistor, Have power through coil to distributor. While cranking I can see spark through the points. Have spark at all spark plugs while cranking. Backfires through the tail pipe while cranking. Fuel in carburetor coming out the drain in a steady stream. Help! Any suggestions appreciated.
