8N Front Distributor Coils
Kola D
I have an 1948 8N tractor s/n 8N101346, 6 volts DC. I bought a new coil for it, to replace an old coil that would work until the tractor got hot. The tractor would not restart after 1-2 hours of use. When I put the new coil on, the cold tractor would not start. Put the old one on and it started right away. I noticed that the spring on the new coil was a different diameter (smaller) than the old one. Contacted the tractor dealer and he said to try pulling the spring out some. Didn't work. He also said that they haven't been having trouble with defective coils. The coil part number is 9N12024 is supposedly for a 1939 to 1950 8N. Everything on the old and new coil looks the same except for that spring. It is like the new coil isn't making contact. Does the diameter of the spring make a difference? Or do I just have a defective coil? Any help would be appreciated.
The diameter of the pigtail doesn't matter as much as the length. It must touch the concave head brass screw in the distributor or you will not have any current to the points.
Pull the distributor off the tractor, put the coil on it & do a continuity check to insure that the coil pig tail is in contact w/ the screw. Then put the coil & distributor back on the tractor as a unit.
50 Tips
I'm think'n I would wire that puppy up and make fire while its on the bench,,, course you gotta remember I don't take a like'n to removing and install'n front mounts as much as others do.... :lol:
Kola.......don't discount the possibility of a DEFECTIVE coil. You should read about 1-ohm between the top terminal and the springy-thingy. And about 4000-ohms to the hi-volts sparkie tab. Iff'n you have "infinity" (open) resistance between the top terminal and enny of yer bottom terminals, guess what??? BAD coil. .......Dell, yer self-appointed sparkie-meister
