8N front loader hydraulic pump
jstraughnmt
I just bought a 47 8N with a Dearborn 19-71 loader. The front hydraulic pump leaks terribly. Looks to be where the drive shaft comes into the pump. I'm hoping to find a rebuild kit for it or, last resort, a new pump. But I have no clue what pump it is. I've googled the numbers I can read on it but I'm not finding much. Can anyone help with identification of the pump or know a rebuild for it? Attached or pics of the pump.
(quoted from post at 11:21:36 08/01/22)
Try a new seal. Pop the old one out and match it up for a new one. If it still leaks after that, replace the pump.
Check out Surplus Center. The closer you get to matching the hook up of a new pump, the less you'll spend. If that's the route you go, post back for some suggested pumps
(quoted from post at 09:03:35 08/01/22)
Thank you for the advice!
Seals,bearings,etc have numbers on them which you can get at a bearing supply store. If it has no numners that you can see,they can measure it. It'll be a rotating shaft seal like a front seal on your car.
(quoted from post at 14:36:05 08/01/22) Seals,bearings,etc have numbers on them which you can get at a bearing supply store. If it has no numners that you can see,they can measure it. It'll be a rotating shaft seal like a front seal on your car.
Thank you!
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto131999.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto132000.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto132001.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto132002.jpg>
Its the "old style" gear pump. Personally, given its age, I would toss it and replace it with a new off the shelf gear pump - $175.
TOH
(quoted from post at 04:43:27 08/03/22)
TOH
I was wondering that myself if I try just try to find new. Thank you!
(quoted from post at 07:49:50 08/03/22)
Po
TOH
These are not expensive and easy to install on your current setup.
10 GPM gear pump - $138
TOH
