8n front loader pump
Bill Gassner
Thanks ULtradog MN When I took pump off I found 1/2 inch or more end play in shaft enough to disconnect from crankshaft pulley.
The only ID I found on pump is 2-69
TSP15-02
HB03010
And on side 9A23D4
Does anyone know how I can get this fixed
Well I ran all those numbers through Google and got nothing for you.
Could you possibly thake some photos of the pump and post it here? Someone here would likely recognize it and be able to offer some advice as to the brand. If you have a good hydraulics repair shop in your area you might take it to them. They could advise you further.
Mind you a new front pump is expensive but sometimes cheaper than parts to repair an old one.
The drive parts - splined shaft, coupler, etc that go from the front of the engine to the pump itself are very common parts.
I did not look but I'm pretty sure the parts department here at this site could sell you most of those items if you decide need new. They could not help you with advice or parts for your existing pump.
Without knowing/seeing what you have I can offer little further advice
Who made your loader? Is there any kind of ID plate on it? My Davis loader has an ID plate on it.
What I'm getting at is if you can ID the loader you can find an online manual for it like I did. They will tell you what pumps were used with that loader.
That may get you a little further along than you are now.
(quoted from post at 20:36:59 08/23/11) Thanks ULtradog MN When I took pump off I found 1/2 inch or more end play in shaft enough to disconnect from crankshaft pulley.
TSP15-02
HB03010
And on side 9A23D4
I'd simply replace it - new pump for $100.
TOH
