Hello everyone. Long time follower but new forum member.
I have a front mount distributor that I have worked on for years when needed and now I'm finding that I can no longer get enough adjustment from the side screw to get the engine running smoothly. We have had this machine as a working tractor for 30 years and I know all the details about keeping the ignition working such a the ignition switch and the like.
The distributor shaft has a fair amount of wear on the the drive tangs and the cam slot has even more wear. The previous owner, obviously to compensate for this, had elongated the slot on the side upward to give more adjustment. In times past, I would redo the points, set the static timing and then slide the bolt on the side up until it ran smooth but this time I'm not quiet getting the popping to go away. I also noticed this time that the flyweights and springs seemed really floppy and so I'm think it's time for a new distributor or new shaft. My bearings are snug since I replaced them not too many years ago.
As for the cam, I might replace it based on what you guys say. I really only want to pull the cam out the front since the engine was in framed years ago and does not smoke, use oil or have low compression.
Questions:
1) What is a good aftermarket distributor or distributor shaft?
2) Have any of you had to replace a cam due to this kind of
wear?
Questions:
wear?
