8n gas tank
Carter W
Is the gallon of fuel in the reserve portion of the 8n tank separate from the rest? If I never open my fuel control valve more than two turns does the reserve portion get stale?
Perhaps someone has a cut out picture of the tank to show me how it works.
Thank you men.
1 tank. oem fuel tap has 2 pipe to grab fuel from tank.. one is taller.. it's the first to open.. grabs higher.. when fuel get to that level ya got only a lil left.. open fully to open the small pipe to get the last drips and dregs out.
usually plugged when ya need it unless you have serviced it.. :)
soundguy
No, it is almost impossible for the 'reserve' to get stale. Think about it---every bump you hit jossles/mixes the fuel in the tank, HOWEVER, if you just drove around a hockey rink all the time............?
come on man.. it's just 1 open sump with 2 different places to suck from.
like having 2 straws in your ice tea.. one an ince from the bottom and one right at the bottom.. all the tea is always mixing when you add new or suck some up.
no 'spare' seperate tank or anything...
soundguy
(quoted from post at 18:38:32 06/25/11) come on man.. it's just 1 open sump with 2 different places to suck from.
soundguy
But what about when you set the glass somewhere for later, and the ice melts ................. you know gets all clear like????????? can't remember if it gets clear-erer at the top or the bottom? dang Ns keep ya think'n don't they.
