Okay,solve this PLEASE!
I"ve had the genny to a good local shop and it was checked. Checked good. Putting out over 7 volts.
The regulator is a new USA made one for this tractor. I momentarily jump wired the arm to bat before starting to polarize. It is wired correctly.
The amp gauge is new, from Just 8 Ns
It shows no charge. It will momentarily show discharge when cranking.
I get about 6.4 v across the battery terminals at 1/2 throttle.
If I ground the field, bypassing the regulator, there is no change in the charge rate.
The belt is new and tight enough you can"t turn the pulley by hand w/o turning the engine over.
All connections are tight, and the connectors are soldered to the wires.
Could it be that the battery is simply charged enough that no amps are showing on the ammeter?
I'm getting very annoyed at this tractor and an alternator is looking better and better all the time! ANY IDEAS? It has to be something simple.
