8N governor parts
r48r50a77
Is there a source to buy small individual parts? I think it is the gear missing that engages the cable to the tach. The tach works off a drill attached to the cable but not the governor. I can something turning in the port. Thank you.
(quoted from post at 11:31:28 08/30/16) Is there a source to buy small individual parts? I think it is the gear missing that engages the cable to the tach. The tach works off a drill attached to the cable but not the governor. I can something turning in the port. Thank you.
this site has what you think you need, look for governor shaft in 8n parts. I would make sure the flex shaft does not have a damaged end before buying parts.
I answered your previous post telling you what is wrong, and that there is no "gear" involved.
Here's a link, in case you missed it:
Tach drive
My 8N tach was missing the little dodad that slips into the back of the governor that will then catch the spaded part of the cable. Is that what he needs..maybe? Someone on here told me that I had to disassemble the governor to slip that piece in and then someone was kind enough to tell me to gentle just tap it in without any disassembly. That worked great! Just wondering.
Yes. Thank you very much. It seems I need the roll pin. The tang is good. Where could I get a roll pin? Thanks again.
This site won't let me post a url to another tractor supply place. If you will put in GRK10, that is the part that you need. Just 8N's has the part. $5.85
If you will put in part number GRK10 and 8N, it will bring up the part that you need. $5.85. Our hosts will not let us post the link to another site. (They don't have that part on here though). It's about $6.
(quoted from post at 12:31:28 08/30/16) Is there a source to buy small individual parts? I think it is the gear missing that engages the cable to the tach. The tach works off a drill attached to the cable but not the governor. I can something turning in the port. Thank you.
b]
Try this......:
GRK10 Years:1950-52 Governor Shaft Bushing(For Proofmeter Cable)
Your Price:$5.85
Quantity
1
GB
If you work at it you can make a roll pin work. The original pin looks like a roll pin.
Original drive pin
3/4" long
OD .312
.075 thick (wall)
grove .095
Standard roll pin
.0320
0.65 thick (wall)
grove ?
I would order the original
