8n hydraulic
swpaguy
Ok. I received my gaskets and piston today. When I put everything back together(top cover, pump base and valve spools) should I use sealer? I didn't find any info on torque specs for the pump base, anyone know what that is.
Swpaguy,No sealer on top cover and only lightly if needed for any imperfections at all on pump bottom cover.
Top or bottom are seeing pressure at the corner.
Rtv is junk.. But there are so high quality sealers that coil work if needed.. Indian read, aviation gasket maker, etc.
